Aggressive ,blaring A String??
H.R.Fisher
PostPosted: Tue May 15, 2007 11:51 am    Post subject: Aggressive ,blaring A String?? Reply with quote
I have this violin that I made that has an open A that has a loud blaring, tinny sound. It is also on the A position on the D string,altho not quite as bad.Otherwise the instrument plays and handles great. What might be the problem,and how could this be corrected? Thanks in advance for your responses, Henry
francois
PostPosted: Tue May 15, 2007 12:54 pm    Post subject: Reply with quote
Seems like a wolf note to me.
Did you bring your instrument to a luthier?
Tried some wolfnote eliminator?
Look at the bottom of this page:
http://www.violins.on.ca/mutes.html
This problem is more likely to happen with cellos and basses though.
Is it a violin you're talking about?
Regards,
François
H.R.Fisher
PostPosted: Tue May 15, 2007 1:33 pm    Post subject: Reply with quote
Thanks Francois, for that abundant response. Smile
francois
PostPosted: Tue May 15, 2007 3:24 pm    Post subject: Reply with quote
Smile
There was a bug with the bulletin board, and I tried to reply a few times...
So, is it a violin, viola, cello?...
H.R.Fisher
PostPosted: Tue May 15, 2007 5:48 pm    Post subject: Reply with quote
Yes, It's a full size violin. Thanks. I tried puting fishing split shot on the A string after length. This seamed to help but also deadend the notes otherwise.
Jack H.
PostPosted: Wed May 16, 2007 1:03 am    Post subject: Reply with quote
Split shot is quite heavy... well... depending on the size.
I would guess that you would need around a quarter gram of weight on a violin or even less.
if you have a gram cale at your beck and call then weigh the weight and try and remove what you can with a file , remove a little and try it again. repeat until the wolf becones predoninant again then get another weight and file it down to the last measured weight that subdued the wolf note.
Most cellos only need between 1/2 to 1+ grams to subdue the wolf, a violin would need a lot less.
good luck.
mikemolnar
PostPosted: Mon Jun 11, 2007 5:12 pm    Post subject: Setup Reply with quote
If your A string is booming, check your bridge and soundpost setup.
