thickness sanding of ribs
actonern
PostPosted: Fri Aug 17, 2007 8:27 am    Post subject: thickness sanding of ribs Reply with quote
I live in the Acton Ontario area and am making a full size cello. The rib stock I bought from Lief needs to be reduced down to the usual 1.5 mm. Does anyone know where, within a commute of 1 hour or so, I could have rib sanding done accurately in a shop?
Thanks in advance
MANFIO
PostPosted: Fri Aug 17, 2007 8:14 pm    Post subject: Reply with quote
In general this work is done with a block plane and scrappers.
www.manfio.com
mikemolnar
PostPosted: Sat Aug 18, 2007 9:50 am    Post subject: Reply with quote
MANFIO is right. But I prefer to use more modern methods such as a sander. BTW, highly figured wood IMHO is better handled with a sander.
PostPosted: Sun Aug 19, 2007 10:36 pm    Post subject: Reply with quote
I'd call either Lief or Heinl in Toronto and ask who the cello makers are in your area...they should be able to help you... Good luck!
M_A_T_T
PostPosted: Tue Aug 21, 2007 10:16 pm    Post subject: Reply with quote
Try local furniture manufactures. I've worked at two in the past and both had thickness sanders.
Making a Violin II
Making a Violin III - Finally Finished
actonern
PostPosted: Wed Aug 22, 2007 11:33 am    Post subject: Reply with quote
Thanks Matt:
I found a place in Burlington "Exotic Woods" that will do it...
Best regards
Leif Luscombe
Site Admin
PostPosted: Wed Aug 22, 2007 1:56 pm    Post subject: Reply with quote
Hi actonern,
Glad you found a place. We used to use a place in London (I don't think they are around any more) to do thickness sanding for fine furniture; it is my only experience with thickness sanders, but it worked like a dream.
Leif Luscombe
Violin Maker and Dealer
The Violin Forum Moderator
PostPosted: Wed Aug 22, 2007 3:00 pm    Post subject: Reply with quote
My son bought one of these tools for thickness planing guitar parts. You are right-- they DO work like a dream. He also bought a dust-collector to keep it clean, and it is a marvellous combination.
bulerias1981
PostPosted: Sun Aug 26, 2007 3:50 pm    Post subject: Reply with quote
What is a good model of thickness sander for this?
"I only write the notes as written, it is god that creates the music." J.S. Bach
PostPosted: Sun Aug 26, 2007 11:41 pm    Post subject: Reply with quote
The one my son has is made by "Jet" -- it seems to work well.
DonLeister
PostPosted: Mon Aug 27, 2007 1:00 am    Post subject: Reply with quote
I have a Performax drum sander that works very well, it's too easy, has a 16" drum , open at one end, I think Delta may have a smaller one out now. You might be looking to spend 6-9 hundred for one maybe.
I also use it to sand joined tops and backs to the correct thickness, and to get the underside of the plate really flat, pretty easy to get it to a tenth of a mil. accuracy. It helps to thickness neck blocks after two edges have been squared too.
You will need dust collection of some kind, a shop vac will work ok.
Don Leister
Andres Sender
PostPosted: Mon Aug 27, 2007 2:06 pm    Post subject: Reply with quote
In case you don't want to spend the money and have lots of time on your hands, there are many recipes out there for home-built thickness sanders, ranging in sophistication from the simplicity of attaching a drum to a motor, to designs which rival high end commercial ones for complexity and quality.
One source for ideas is the GAL publication Lutherie Tools. I built one out of 2 x 4s with a 4" drum made from plywood and particle board discs mounted on a cold-rolled steel mandrel and sanded to final shape against the platen, it's been working great for 10 years.
PostPosted: Mon Aug 27, 2007 11:16 pm    Post subject: Reply with quote
In case you have not seen this...
http://www.mimf.com/archives/thickness_sander2.htm
PostPosted: Wed Aug 29, 2007 12:08 am    Post subject: Reply with quote
here is a small one ... might be just right for violin ribs
http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=Product&ID=83507
M_A_T_T
PostPosted: Mon Sep 10, 2007 12:15 am    Post subject: Reply with quote
I used to have a Performax 16" open-ended one (you could sand a board up to 32" wide in two passes). It worked great the few times I used it but prefer to use handplanes for that type of work and sold it. I think Performax have a 10" bench top model. You will definately need a dust collector with it, I bought a 1HP model that worked well and I still use it with my bandsaw. The one Mat Roop posted it neat.
Making a Violin II
