Ivory tip glue and clamp
wm_crash
PostPosted: Fri Jun 13, 2014 5:10 pm    Post subject: Ivory tip glue and clamp Reply with quote
Hi,
Today I had my first attempt at a rehab of an old snakewood bow. Part of the tip was missing and the ivory wasn't there. I fixed and shaped the tip alright, and then tried to glue the ivory. I decided to use G2 Flex epoxy, don't ask why. Turns out cure time is like 10-12 hours. Gluing was a pain, I had the bow on a rehair clamp and even then, had trouble getting the string around it to hold it down. In the end, I used some small quick grip clamps, but it's not an ideal situation.
I like the Lemuel tip clamp, and I will probably get one of those. If anyone has something else in the mean time, I'd like to give a try. As much as I do woodworking, I hate building my own jigs for anything.
cheers,
PostPosted: Sat Jun 14, 2014 12:49 am    Post subject: Reply with quote
wmc.... Your experience is exactly why that tip clamp on Lemuels web site was developed!
https://www.violins.ca/info/violin_bow_tip_repair.html
Cheers... Mat
whatwasithinking
PostPosted: Sun Jun 15, 2014 4:42 pm    Post subject: Reply with quote
You're a brave man to use ivory! I'm sure the feds won't come for you...today, anyway.
wm_crash
PostPosted: Mon Jun 16, 2014 9:39 am    Post subject: Reply with quote
Oh it was mammoth tusk ivory, and I do have the receipt. But will they believe me?
cheers,
whatwasithinking
PostPosted: Mon Jun 16, 2014 10:07 am    Post subject: Reply with quote
cheers,
I think that's the question. As an alternative, casein looks a lot like ivory. Bends a little more easily, too.
wm_crash
PostPosted: Mon Jun 16, 2014 11:17 am    Post subject: Reply with quote
Has anyone tried elk/deer antler? Or is it too porous to be used?
cheers,
