best light for inside violins
PostPosted: Fri Apr 17, 2015 8:47 pm    Post subject: best light for inside violins Reply with quote
What do you folks use that you find particularly good for lighting the inside of a violin when you do inspections and sound post work?
Thanks!... Mat
PostPosted: Sat Apr 18, 2015 8:11 am    Post subject: Reply with quote
Any sporting goods store sells "bore" light, its about 6mm dia, flexible shaft about 6" long. I stick it through lower F hole. Maybe $5.
Cliff Green
PostPosted: Sat Apr 18, 2015 8:14 am    Post subject: Reply with quote
I've used the flexible shaft pen lights but the luthier lights by Doug Wall at Maestronet are like stadium lights.
http://www.wallindependent.com/Luthier%20Lights%20%28.com%29.htm
PostPosted: Sat Apr 18, 2015 8:42 am    Post subject: Reply with quote
Cliff, those look pretty nice, so you can probably use it hands free?
FiddleDoug
PostPosted: Sat Apr 18, 2015 8:42 am    Post subject: Luthier Lights Reply with quote
Cliff,
Thanks for the endorsement!
I make and sell them.
Also on Facebook
https://www.facebook.com/pages/Luthier-Lights/568558886590569?ref=aymt_homepage_panel
Doug Wall
DonLeister
PostPosted: Sat Apr 18, 2015 12:39 pm    Post subject: Reply with quote
Hi Doug, the first link isn't working.
I like the lights btw!
FiddleDoug
PostPosted: Sat Apr 18, 2015 1:31 pm    Post subject: Try that again Reply with quote
Fixed
Doug Wall
PostPosted: Sat Apr 18, 2015 5:48 pm    Post subject: Reply with quote
I made my own, but agree that it is the best I've ever tried.
kjb
PostPosted: Sun Apr 19, 2015 7:29 am    Post subject: Reply with quote
I made mine out of curiosity, but to to get the materials and using my own transformer, it still cost about what doug is charging, if you are only making one, your are probably better off with dougs.
FiddleDoug
PostPosted: Sun Apr 19, 2015 9:31 am    Post subject: Reply with quote
Just a note to the DIY crowd. I recently purchased a roll of inexpensive LED ribbon on Ebay for a different lighting project. I was VERY disappointed with the product. The light output was MUCH lower than the strip that I use for the Luthier Lights, and the color was off. I buy my LEDs from a very high end supplier, and pay almost 10 times what the cheapo LED ribbons cost. As far as I'm concerned, it's worth every penny to supply a quality product.
Doug Wall
PostPosted: Mon Apr 20, 2015 11:03 pm    Post subject: Reply with quote
Thanks everyone... Just wondering what might be new out there...
I have a a DIY led strip I built a few years ago... Got the light strip from an auto surplus.. I just use 1 model for all... it has 9 led's and is about 6" long works OK, not sure of the light output... but my power supply alone cost about $25!
I'm calling Doug next time!
ollieken
PostPosted: Sun May 03, 2015 7:42 am    Post subject: light Reply with quote
Hello Mat I went to Princess auto & they had a L.E.D.strip light with
21 clear light`s I had a transformer 120 ac to 12 volts dc in my cant throw out stuff sure lights up the fiddle I think I can cut some out as it
is a long strip thanks . Ken
John Masters
PostPosted: Thu May 14, 2015 1:52 pm    Post subject: best light for inside violins Reply with quote
Nobody mentioned this, so I will. A good hobby shop sells all sizes of model train mini-lights. They are all 12 volts. Turns out the BIGGEST ones are only about a cm long and 4mm diameter. I take two or three of these in paralell and solder to the long pigtail out of a plug-in transformer.
They last a long time and are cheap. I line them up and put some masking tape on the solder joint. And much smaller ones are also made, although of smaller wattage.
They are purely incandescent and non-directional.
FiddleDoug
PostPosted: Thu May 14, 2015 8:26 pm    Post subject: Re: best light for inside violins Reply with quote
I seriously doubt that they could "hold a candle" to Luthier Lights. The violin size puts out 47 lumens of daylight white light with almost no heat.
Edit- From another website about model railroad lighting-
"Compare that to a GE 14 volt Midget bulb which gives approximately .3 lumens"
Doug Wall
PostPosted: Sun May 17, 2015 7:14 pm    Post subject: Luthier lights Reply with quote
I like my little "bore light" it fits in my pocket, no cords, no transformers, LED no heat at all, and I don't have to wear my sunglasses.
