gluing fingergrip
PostPosted: Wed Nov 11, 2015 10:13 am    Post subject: gluing fingergrip Reply with quote
What is the best materials and method to glue a new snakeskin finger grip to a permanbuco bow?
I have generally used contact cement, easy to work with and clean up, but in time with lots of sweat, it seems to work loose. I am reluctant to try synthetic glues wondering if it will hold to pernambuco... and epoxy just seems too permanent and challenging for the cleanup.
What do you use?... Thanks, Mat
whatwasithinking
PostPosted: Wed Nov 11, 2015 10:10 pm    Post subject: Reply with quote
Hi Mat,
Titebond. I'd avoid epoxy.
Bob
PostPosted: Fri Nov 13, 2015 8:22 pm    Post subject: Reply with quote
I've used rubber cement, coat surfaces to bond, let it dry, and just roll it into position, won't move, instant grip.
whatwasithinking
PostPosted: Fri Nov 13, 2015 10:50 pm    Post subject: Reply with quote
I just noticed your post on MN. Yup, I follow Josh's method. I think most makers do something similar. I like Titebond better than white glue, and probably some use hide glue. Never heard of using rubber cement, so can't comment on that.
Franciscus
PostPosted: Sat Nov 14, 2015 4:14 am    Post subject: Reply with quote
whatwasithinking wrote:
II like Titebond better than white glue...
Titebond makes a lot of various glues, including the white glue. Which one you prefer to use here?
whatwasithinking
PostPosted: Sat Nov 14, 2015 10:08 am    Post subject: Reply with quote
Titebond Original wood glue. Depending on the nature of the wrap, this may be applied directly to the wire/tinsel/whatever, or to a paper wrap, allowing a shorter piece of wire. Then I can manipulate the weight and balance a bit, at the same time, particularly when wire is used.
Nick Walker
PostPosted: Sun Nov 15, 2015 6:49 pm    Post subject: Reply with quote
I know Rodney Mohr uses straight up school type white glue with a painter tape underlay. Josh uses a water activated paper tape underlay and I think just white glue. The thinking behind the white glue is reversibility. Simply covering with a water soaked rag for a bit will loosen the water soluble white glue making replacement very easy.
whatwasithinking
PostPosted: Sun Nov 15, 2015 9:57 pm    Post subject: Reply with quote
Hi Nick,
Well, then I have a higher esteem for white glue!
Josh describes his glue preference in the comments of his youtube video.
Bob
PostPosted: Tue Nov 17, 2015 1:18 am    Post subject: Reply with quote
Thanks for all your kind advice!.... still debating on what to use....For this job I still like the contact cement idea because the snakeskin is stiffer than usual, and if I'm using Titebond I'd like some assurance that the tack will hold while I can still cleanup.... not convinced. I will however try the titebond on the next leather grip.
