Posted: Fri Oct 05, 2007 9:52 pm Post subject: humidity and corpus glue-up |
In Ontario, Canada, the humidity swings between winter and summer are dramatic and the swelling and shrinking effect on wood equally so.
I've found that the best time to glue the top/back plates to the rib structure is at a time of year that approximates the "middle" of the humidity cycle... around November and March.
This approach (I'm an amateur with no sales pressure!) may not be feasible for professional makers. How do those without the luxury of time approach this issue? A cello top, for example, can in my environment easily shrink 5 mm between maximum and minimum humidity cycles. That is a recipe for saddle cracks etc.
Old stable wood is an obvious advantage, but I wonder how a body glued up in summer will preserve stability of tone in the winter months... |
Jeffrey Holmes Member
Posted: Fri Oct 05, 2007 10:47 pm Post subject: Re: humidity and corpus glue-up |
actonern wrote: | This approach (I'm an amateur with no sales pressure!) may not be feasible for professional makers. How do those without the luxury of time approach this issue? A cello top, for example, can in my environment easily shrink 5 mm between maximum and minimum humidity cycles. That is a recipe for saddle cracks etc. |
By controlling the humidity in the shop (humidification/dehumidification). _________________ Jeffrey
http://holmesviolins.com |
