edge glue application
Greg M
PostPosted: Fri Oct 27, 2017 7:13 pm    Post subject: edge glue application Reply with quote
Hi I read in a couple of blogs that prior to cutting the purfling channel , it is a good idea to apply hide glue to the side of the violin and the outer side of the purfling channel to prevent splintering . I thought that dried hide glue would not allow the stain to penetrate.
PostPosted: Sat Oct 28, 2017 12:58 pm    Post subject: Reply with quote
I do occasionally get a spliter break off between the channel and edge usually at the bottom near the saddle area, sometimes the little inside corner wedge where the purfling meets in the corners, usually the spruce. I superglue it back in and keep going. I don't think spreading glue around the edges will make a difference, but hey, I've not considered doing that. I don't consider it an issue unless you're rough with your tools. Usually happens when I'm tired or in a hurry.
By the way, superglue works much better if you dampen the surfaces to be glued. In this case, I just dampen it with my tongue --- before putting the super glue on!! I don't advise doing this the other way around.
Greg M
PostPosted: Sat Oct 28, 2017 4:13 pm    Post subject: super glue edges Reply with quote
Thanks for that bit of information . this site is great for getting helpful information. I have bought the wood and am going to build a jig for my router to cut the purfling groove , if that is too powerful , I will build a jig and buy the dremel 3000 which probably has less amps. Lee valley sells the bits .060 and .040 " with the 1/4" shank. I have even experimented with drilling a 1/16" hole all around with a dowel as the guide pin , then cut the rest out by hand, this option at least gets the desired depth of cut all around.
PostPosted: Tue Oct 31, 2017 11:28 pm    Post subject: Reply with quote
Interesting thread on cutting purfling channel... Cheers, mat
https://maestronet.com/forum/index.php?/topic/339246-purfling-cutter-rig/
