M_A_T_T Member
Posted: Tue Dec 11, 2007 9:23 pm Post subject: |
Wow, $150? You're paying $100+ for a fancy engine turned surface. I've made two from $5.00 sheets of 1/8" thick aluminum. One I sold to a violin maker in Canada for $20 and the other I kept for myself.
Here is the one I kept for myself, much like Michael's and Andres' design, except it has legs to support itself.
I also glued the bar while the top was in the frame.
Here is the first one I built, the violin maker I sold it to helped design it. I gave it built in clamps, which I found with my second one were really unnecessary as any little spring clamp will do, and it also has the legs which were my idea. (ignore the top in these pics, it was a pre-carved sample a company sent me)
If you can make a violin, you can make one of these. I used my band saw with a 1/8" 14TPI blade to cut out the outline, than drilled a hole in the middle and used a coping saw with a fine blade to cut out the inside. After that alot of file work is required. _________________ Making a Violin II
Making a Violin III - Finally Finished |
violinarius Member
Posted: Sat Dec 15, 2007 4:33 am Post subject: Re: Looking for aluminum frames |
Jack H. wrote: | for violin and cello.
Any one know where to get one? |
This sounds like a good job for someone who does CNC.
In most cities there should be someone who offers such a service. |
Posted: Sat Dec 15, 2007 6:45 pm Post subject: |
Right, but CNC doesn't work magic as far as economics. It takes time to do the programming of the machine even if one provides a CAD drawing. So to get the price into a reasonable level one needs to make a quantity and spread the setup cost out.
My frames were cut from a CAD drawing, but if I'd had only one made it would have cost several hundred dollars. |
M_A_T_T Member
Posted: Sun Dec 16, 2007 1:57 am Post subject: |
My work does loads of CNC work, we have several CNC mills and lathes. I had a bending iron form CNC'd after drawing the shape in CAD.
We actually do quite a bit of 1/8" sheet aluminum CNC'ing for the drywall tools we manufacture. The aluminum sheet I made my frames out of is the same stuff we run in the machines regularly for our production.
I could inquire about costs and time for making such a product. We seem to be somewhat slow right now, might be a good time to ask.
What is a good thickness for the frames? Mine are 1/8" but i think Andres' are 3/16"? I didn't notice mine to flex when using it, nor has the maker I sold one to. I think Michael also once mentioned he bends his frame to fit any distorions in his tops, which would be easier with a thinner frame. _________________ Making a Violin II
M_A_T_T Member
Posted: Fri Dec 21, 2007 4:34 pm Post subject: |
I talked to my boss today about CNC'ing some frames. I didn't have mine with me but explained to him what it was. He said off the top of his head it might cost only $9 in material & machining time @ $1/minute + $5 for the sheet. The CAD drawing can be written up by me after hours on my time. The sheets of aluminum that are held in the machine by an existing jig are big enough to do violas as well, they are 12" x 18". _________________ Making a Violin II
M_A_T_T Member
Posted: Fri Mar 21, 2008 2:34 am Post subject: |
This is a prototype I had made. The design is Andres Sender's, who sent me the design and allowed me to use it. It's cut from a sheet of 1/8" anodized aluminum. Some kinks still need to be worked out in regards to how it is cut out. _________________ Making a Violin II
Posted: Fri Mar 21, 2008 1:11 pm Post subject: |
Looks nice!
Might have to make ait a bit narower on the inside to use it to work on. looks like it hangs over a bit into the work area.
I would order at least 4 or 5 at that price adn pay for shipping and handling... |
M_A_T_T Member
Posted: Fri Mar 21, 2008 1:15 pm Post subject: |
Jack H. wrote: | Looks nice!
Thanks. I don't have a top on hand to check the fit, but it's the exact same design as the one Andres Sender posted earlier in this thread. I am interested in getting more made and selling them. Just not sure of the best method to go about doing that. _________________ Making a Violin II
Posted: Fri Mar 21, 2008 1:28 pm Post subject: |
advertize in the strad magazine or other trade mags.
Start machining tools from aluminum and brass, like those wonderful crack clamps and things and word will get out if you have a simple web site or catalogue. |
Posted: Fri Mar 21, 2008 3:21 pm Post subject: |
Jack--the design was carefully worked out (with help and feedback from Michael Darnton) to allow access to the bassbar area in a wide variety of violins while also being clampable to a wide variety, I doubt you'd run into problems even on larger instruments. Frames of this design are currently in use in a certain shop in Chicago.
Matt–The anodizing is nice! You’ll have no trouble moving these if you just contact the various workshops or schools I’d bet. |
Posted: Fri Mar 21, 2008 4:06 pm Post subject: |
Hey Andres, I figured it would be ok for the bass bar, I had a thought for a fleeting moment that it might interfere with interior work, but you only realy use a frame for the bb and to make a counterform, in which care you are right, it would not get in the way. |
WNitkin Junior Member
Posted: Fri Mar 21, 2008 11:31 pm Post subject: Frame |
If you have any frames for sale please let me know!
WNitkin@aol.com |
mapleleaf_gal Member
Posted: Tue Mar 25, 2008 1:25 pm Post subject: |
i used pegboard to cut mine. it works great. it is stiff, but you run less of a chance of injurying any part of the wood and i'm sure it is less heavy as well. i used the "holeless" kind of pegboard. _________________ http://sgwhiteviolins.googlepages.com/home |
Posted: Tue Mar 25, 2008 1:30 pm Post subject: |
That would be masonite I think?
Some use clear acrylic also. |
M_A_T_T Member
