Violin strings?
violinguy
PostPosted: Thu Feb 07, 2008 12:02 am    Post subject: Violin strings? Reply with quote
How much do new, higher end strings make in the sounds you'll produce? ??? I find my strings seem not too bright and a bit dead. It's a new violin that is not entry level but not much above that. Thanks
vg
Jack Rushing
PostPosted: Sat Feb 09, 2008 10:42 pm    Post subject: Reply with quote
Hi VG, Assuming that your bridge and soundpost are in the correct position
to start with, Yes, The kind of strings you are using can make a difference.
There are many, many different opinions on what is the best strings to use.
If you want a good, soft, low tension string, I would recommend Violinos.
If you want one a little brighter, with a quicker response, try a set of
Corelli Crystals. Later, as you advance in your studies, you might want to try a set of Dominants. Good Luck in your search for a string that you like.
little lady
PostPosted: Mon Feb 11, 2008 1:57 pm    Post subject: Reply with quote
Hi Violinguy
Remember that new violins take some time to play in; the sound should change over time if you continue to play it enough.
But if you feel your strings are producing a dead sound, you probably should try some new ones. Oftentimes violins are sold with old or poor-quality strings.
It may take some time to find the strings that are ideal for you and for your violin. Most beginners start with metal strings. I think Helicore is a good quality metal string. As you progress, you will want a warmer sound and Dominant (which is not metal but perlon) will be a good next choice.
Good luck and enjoy!
spystyle
PostPosted: Mon Feb 18, 2008 3:21 pm    Post subject: Reply with quote
I've read that "Red label" is OK for beginners (first year) then to move onto "dominant" - I hear that over and over.
Apparently "Dominant" is the coolest strings. The same company (Thomastik) has made a new string called "Vision" - I wonder if they are as good as "Dominant" ?
Have any of you tried both Dominant and Vision ?
Cheers,
Craig
Elkwoman46
PostPosted: Mon Feb 18, 2008 4:24 pm    Post subject: Reply with quote
Just curious...are those highly esteemed "gut strings" still available at all?
If so, what do they go for?
Thanks.
spystyle
PostPosted: Mon Feb 18, 2008 4:46 pm    Post subject: Reply with quote
Thanks.
GUT STRING MAKERS
Aquila String Makers
16 via Constantini
36100 Vicenza, Italy
American distributor:
Curtis Daily
Aquila USA
PO Box 82761
Portland, OR 97282
Phone/fax (503) 788-5029
www.aquilausa.com
Boston Catlines
34 Newberry St.
Somerville, MA 02144
Phone/fax (617) 776-8688
catlines@aol.com
Bridgewood and Neitzert
146 Stoke Newington Church St.
London N16 0UH, England
(44) 171-249-9398
Fax (44) 275-9330
Damian Dlugolecki
520 S.E. 40th St.
Troutdale, OR 97060
(503) 669-7966
damian@teleport.com
www.damianstrings.com
Gamut Strings
Dan Larson
26 N. 28 Ave. East
Duluth, MN 55812
Phone/fax (888) 724-8099
www.daniellarson.com
Northern Renaissance Instruments
6 Needham Ave.
Chorlton-cum-Hardy
Manchester M21 2AA, England
Phone/fax (44) 161-881-8134
www.nrinstruments.demon.co.uk
William Monical & Sons
288 chmond Terrace, Staten Island, New York, NY 60201
pohne: (800) 816-4424
Fax: (718) 816-771
Wmonical@con2.com
Pirastro
www.pirastro.com
Available through most dealers
Elkwoman46
PostPosted: Mon Feb 18, 2008 5:40 pm    Post subject: Reply with quote
oh Craig...
Thanks so very, very kindly! I have now looked at most of the offerings! Thanks so much!
God bless you!
spystyle
PostPosted: Mon Feb 18, 2008 6:08 pm    Post subject: Reply with quote
No problem, I just Googled it Smile
