masterbass Junior Member
Posted: Thu Mar 13, 2008 11:11 am Post subject: Violin Fingerboard |
Hello,
It´s the first time I unglue a fingerboard. Could the Experts tell me any advise or procedure to do it? It´s bassically the same operation in all stringed instruments?
thank you _________________ www.contrabajo.es
www.forumcontrabajo.foroactivo.com
Spanish doublebass site |
Posted: Thu Mar 13, 2008 12:21 pm Post subject: |
I use a clothes-iron to warm the ebony through. Then I use the iron to heat a very thin, dull knife, and slide it btween the FB and neck. Usually that works very well. Go slowly, and be careful where you are pointing that knife when you push.
Sometimes a small amount of alcohol will help dehydrate the glue and make it more brittle. Just don't spill it on the varnish-- drip it on the knife blade, and let it run into the opening. |
Posted: Thu Mar 13, 2008 1:13 pm Post subject: |
Chet Bishop wrote: | I use a clothes-iron to warm the ebony through. |
Do you apply the iron directly to the ebony?
Thank you _________________ www.contrabajo.es
