Bending ivory to fit tip
PostPosted: Sun Aug 17, 2008 10:34 pm    Post subject: Bending ivory to fit tip Reply with quote
I have an old bow I want to fit with a real ivory tip liner. A friend has given me a piece of ivory from an old piano key. The question is ...what is the technique to bend ivory to fit the contour of the bow tip?
Thanks... Mat
Leif Luscombe
Site Admin
PostPosted: Mon Aug 18, 2008 10:46 pm    Post subject: Reply with quote
Hi Mat,
I usually heat the tip over a flame.
Leif Luscombe
Violin Maker and Dealer
The Violin Forum Moderator
PostPosted: Wed Aug 20, 2008 1:12 am    Post subject: Reply with quote
Thanks Leif... Never worked with ivory, and I only have a small piece... don't want to mess it up. Thanks for the tip!... Mat
Jack H.
PostPosted: Wed Aug 20, 2008 12:33 pm    Post subject: Reply with quote
You might want to use a hair dryer or a heat gun the first time out so as not to burn the ivory.
I use a hot water bath and a top bending jig. You can also make a 2 part wooden jig exactly to fit the curve and press it in htat. when bending, go slowly.
Jack
PostPosted: Thu Aug 21, 2008 12:14 am    Post subject: Reply with quote
Thanks Jack... How hot is the water to soak to ivory?...I like the jig idea... thanks, Mat
Jack H.
PostPosted: Fri Aug 22, 2008 5:12 pm    Post subject: Reply with quote
Boiling
PostPosted: Sun Dec 14, 2008 3:51 pm    Post subject: Reply with quote
Thanks for all the good advice... I have been slow at getting to this, but in the end it all worked out well... I boiled the ivory then bent it in a mold that matches the head. I was able to make 3 tips out of the one piece of ivory... not much to spare though!. I made a jig to clamp the tip and it worked well as this jig gives me full view all around to be sure it is aligned perfectly. I used G2 epoxy... set overnight and it came out good.
[/list][/list][/url]
Jack H.
PostPosted: Mon Dec 15, 2008 2:17 am    Post subject: Reply with quote
big jig for such a small job, but if it works that is what matters.
Glad to hear it came out well!
