Glue Pot, Electric 110V
Item: #TD4001
Water-jacketed glue pots for the uncomplicated heating of hot-setting adhesives, priming and waxes. A built-in thermostat ensures the correct temperature within +/- 3° C. Designed for constant professional use, these glue pots have proved themselves over and over again in woodworking, resto­ration and instrument making. Nickel-plated brass housing with heat-resistant plastic handle and slip-proof base. Maximum temperature approx. 85°C. Double-chambered container, 1/3 divided, for simultaneously heating glue and water (for thinning purposes). Made of polypropylene; tough, heat resistant and chemically neutral. Capacity 0.25 L.
Ø 105 mm, height 160 mm, 120 W, 110 V.
$ 688.60
